Grit_dog
Mar 23, 2023Trailblazer
BB_TX wrote:johndeerefarmer wrote:BB_TX wrote:way2roll wrote:
I would research the requirements in your state. It's binary, either you need a different license or you don't. If you need it, get it. It's pretty simple. Anything worth doing is worth doing right. The question about whether you get pulled over and the consequences is just noise. If you have the proper license it's no longer a question.
I was in an interesting situation pertaining to a Texas DL.
Class A - a combination of vehicles with a combined GVWR of 26,001 lbs and towing a trailer with a GVWR greater than 10,000 lb.
Class B - a single vehicle with a GVWR of 26,001 lb or a combination of vehicles with a combined GVWR of 26,001 lb and towing a trailer under 10,000 lb.
Class C - a vehicle not falling under class A or class B towing a trailer with a GVWR of under 10,000 lb.
My truck/5er conbined GVWR was under 26,000 lbs. So I did not fall under the class A license. Or class B. But my 5er GVWR was about 14,000 lb, so did not fall under class C. So my situation did not meet any of the requirements. I continued to tow with my class C wondering how a LEO would respond if I got stopped and he questioned my license class and I then ask him what class I should have based on my weights. :h Never got stopped to find out.
Class C is fine for what you have. Many hotshoters have their truck derated to 10k lbs (which is why Ford offers this option when you order) and with a truck rated at 10k they can tow a trailer with a GVWR of 16k and still only run Class C
Registration on a 10k truck is cheaper and so is insurance I think
Not according to the definition of class C. It specifically says a trailer not to exceed 10,000 lbs. My 5er was about 14,000 lbs.
A single vehicle with a gross vehicle weight rating (GVWR) of less than 26,001 lbs. towing a trailer not to exceed 10,000 lbs. GVWR or a farm trailer with a GVWR that does not exceed 20,000 lb
Correct, so you clearly don’t fall in A or B class by those definitions, and the first line for a class C says something like “any vehicle or combo that doesn’t fall under A or B.”
Therefore C is the correct answer. And additionally class C doesn’t say under 10klb. Only farm trailers under 20k. Maybe the lingo changed since back in the day but idk.
Looking for advice before your next adventure? Look no further.25,213 PostsLatest Activity: Sep 06, 2026
