VintageRacer
Aug 04, 2013Explorer
A difference not mentioned so far is tongue weight - the flat tow will have no tongue weight while the trailer will have substantial tongue weight - probably 600 - 700 lbs if you can get the load balanced correctly, which may actually be quite hard to do. With a long Class C you usually have a very long tail behind the rear axle, which makes the effect of tongue weight quite high. While I prefer to tow a trailer for all the reasons given above, the tongue weight in this situation would make me favor the flat-towed truck.
Brian
Brian
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
