blt2ski
May 01, 2017Moderator
drsteve wrote:
Too much tongue weight can exceed the rating of the hitch receiver when not using WD. The numbers are on the receiver. On my truck, it's 500 lb tongue without WD, 1000 lb with. Max trailer is 5000 without, 10,000 with.
Again, these are receiver ratings, not the truck itself.
If you want to dead weight more than the current receiver gives you, and you are with in specs of the tow rig. Get a heavier duty hitch!
WHat I have personally found with a WDH system. IS when you take off a certain amount of weight from the front axel, usually about 300 lbs for the SW 35 series trucks I've had in the past, the steering etc gets bad/goofy, what ever term you want to call it. A WDH will put the wt taken off the front to the rear axel, and put it back to the front, putting truck steering/handling back to what I will call a normal feeling.
When towing my TT without, vs with, and vs with a sway control. I found in cross winds, the trailer rocked side to side less with a dual cam set up, than a basic WD, vs no bars what so ever. I never had fish tail sway with that trailer, so can not comment on this. BUT< having been hit by what I will swag was something over 50 mph based on known wind speeds going over the Columbia from Portland to Vancouver, with the dual cam, I did move half a lane to left with said gust. Everything went as one! As did many other rigs on the bridge I was on.
As noted, as the hitch head drops from slightly raised, to level, to lower than level, wt gets taken off the FA, and trailer axels, and placed on the rear axel. Some is ok, you will not notice this, too much makes for a bad handling rig. Hence why a WD can make or break a given rig.
I'm also of the, if the trailer does not tow well without bars, find and FIX the issue for said bad handling if it moves say side to side uncontrollably. If all you do is slap on an anti sway device, this is putting a band aid on a cut, that needs a tourniquet. You still have a trailer that wants to sway.
Marty
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
