wny_pat1
Oct 07, 2013Explorer II
nickthehunter wrote:There are two valves on a ASME motorhome tank. The main valve feeding the house system has to be turned off to fill. I have never seen any service person not turn it off when fueling!!! I think that is what the OP is talking about, a mounted, attached, motorhome ASME tank. A Dot tank only have one valve and would have to be disconnected from the system to fill it I would think.wny_pat wrote:I don't know of any other way to "fuel" a LP tank except with the "LP Tank's main valve turned on" (open)??
.... It is also a violation to fuel the LP tank while the LP tank's main valve is turned on, which is part of the same fire codes. .... Stupid is as stupid does!
Looking for advice before your next adventure? Look no further.25,210 PostsLatest Activity: Aug 29, 2026
