RJL's avatar
RJL
Question on a Jeep Wrangler toad (2010 JKUR) Key on/off?
We left Friday morning from SW Fla enroute home to S. Jersey. Later in the early afternoon a Ford pickup towing a camper pulled next to us on 95 N and said our red cable was dragging. Luckily I was a mile and a half from a rest stop so we pulled in, sure enough our power cord that charges the battery as we're driving had dragged for a bit and was destroyed. I unhooked it, started the Jeep and let it sit while we had lunch. After placed the key in the "acc." position and continued on until 5 and pulled into a CG. Started the jeep up again, shut it down and and grabbed some sleep. The next morning I plugged in our "Brake Buddy" system preped it for the drive that day, put the key in the "acc." position and left at 0700. Fast forward to 2/p and the sensor that plugs into the cigarette lighter begins to flash red, then stays glowing red, indicating something is wrong with the "Brake Buddy". Pull off in VA and sure enough the battery is completely dead. Take the power cord out of the cigarette lighter in the Jeep and finish our trip that day (Saturday) and arrive home yesterday with no supplemental braking system or blinker/stop lights on the Jeep. My question is does the key have to be in the acc. position, or can it be off. I noticed that when the transfer case is in "N" and the transmission is in "P" that I can move the steering wheel with no lock, however the Jeep manual clearly states the key must be in the acc mode while flat towing. I read in here somewhere that it's not necessary to have the key in acc position and that it's ok to have it off. Which is it? The reason I ask now is my battery in the Jeep is trashed and I'm wondering if I just put the ignition in the off position when I lost the cable I might have been able to save the battery.
Sorry for the book.
Bob
  • Thanks for all the replies. The owners manual is confusing, key in acc, negative battery cable off, but the Brake Buddy needs power to brake assist and I'm assuming the Jeep needs power for the turn signals, which is supplied by the cord that got mangled on our trip north. Sooooo, I guess, after thinking about this and the messages here I need the key on as long as I'm using the BB and actually want some blinkers and brake lights.
    Thanks again all,
    Bob
    Sorry for the book.
    Bob
    As long as you don't need ACC for 12vdc power, you're good to go, as the 2010 Wranglers do not have a steering lock.
    As for toad braking, I'd trash the brake buddy and go with a READYBRAKE for trouble free simplicity. Just IMHO of course.
  • This statement under "Disabled Towing" for the Wrangler throws folks off, including myself:
    Without The Ignition Key
    Special care must be taken when the vehicle is towed
    with the ignition in the OFF position. The only approved
    method of towing without the key fob is with a flatbed
    truck. Proper towing equipment is necessary to prevent
    damage to the vehicle.
  • The answer here is really easy! After you remove the key is the steering column locked? It's easy to test just turn the steering wheel 180 degrees and if it can be returned to center you don't. In this case just remove your key and get on with towing...
    Sorry for the book.
    Bob
    Hey Bob,
    I just pulled up a '10 JK owners manual on line and, to me, it doesn't make any sense. In step #8, it says to turn the engine off and turn the key to "ACC" position.
    But, in step #13, it says to disconnect the negative battery cable and store it away from the battery.
    Now, are they wanting you to put the key in the ACC position just to make sure the steering is unlocked? And that disconnecting the negative battery cable is to insure there is no battery drain due to certain parts of the electronic system being activated by leaving the key in the ACC position? If those two assumptions are correct, then yes, now it makes sense.
    Scott
  • At some point in time Jeep changed to not needing the key left on. Even our 2012 manual says to leave the key on. But online there was an updated manual somewhere that said you did not need to. And it was only because of the steering wheel lock. So, if yours does not lock you do not need to leave the key on.
    But, you can not use the cigarette lighter socket in the dash since it is only on with the key on. Instead, use the one in the center console.
    Previously, when we had a smaller motorhome and larger toad, we did set the Brake Buddy to to provide proportional braking and it needed a battery charge line. Currently we are set up to use only emergency braking and it does not need the battery charge line.
    David
Looking for advice before your next adventure? Look no further.25,177 PostsLatest Activity: Nov 17, 2025
