SoundGuy
Nov 06, 2018Explorer
riven1950 wrote:
I have never used a cable pull. I can see they would open when you pull the cable, but how do they close? I'm sure the person doing the walkthru will explain but thought more info is better.
Just push it back in. ;) The problem is later on when those cables begin to stick and you find it impossible to fully close the drain valves. Happened to me on my Spree, cut 'em off and replaced them with direct pull Valterra drain valve assemblies - problem solved. :B
Looking for advice before your next adventure? Look no further.25,196 PostsLatest Activity: May 17, 2026
