Yeti_plus
Dec 16, 2017Explorer
The straw screws onto the trigger. You have to operate the trigger to make the foam flow.
It expands like crazy so be careful that you don't put too much in as it can break or move things that get in its way. Since you can see the ground through the hole you should block it off underneath. duct tape or cardboard to cover the hole should work.
And as others have said, throw out the can when you are done because in a day you can't use it again.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
