Halmfamily
Dec 09, 2015Explorer
If you're using a modern woodstove they reburn the exhaust before it heads up the chimney. Our stove is extremely efficient with no visible smoke once fully heated. Use a spark arrester and you should be fine. As said many areas require an arrester as ours does to prevent a forest fire. The spark arrester needs to be cleaned yearly with your chimney to remove soot and keep the woodstove at its peak efficiency.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
