2012Oudoorsman
Jun 24, 2013Explorer
Desert Captain wrote:
The other indication of an overloaded truck is the fact that you have air bags AND sag. :C
Just so others know. Yes I do have airbags but this is not for the travel trailer at all. I haul a decent amount of firewood and wanted it for extra caution. The min psi you can run in the bags i have is 5psi and max is 35 psi. I run it at about 8-10 psi when towing as I never like to have things maxed nor near the minimum. These when air downed don't do anything as you can practically push the bags in with your finger. I have noticed that when aired up they hurt the wdh as they dont allow it to do its job which many already know.
There is absolutely no sag when wdh is set up in fact i can easily jack rear end up higher and lower front with hitch as i did it when trying to set hitch up with wheel well measurements.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
