2012Oudoorsman
Jun 24, 2013Explorer
nohurry wrote:
All I can think of is
You DON'T want to grease the friction points. I grease mine at the swivel points where the socket that holds the bars swings back and forth
I think we're talking about the same thing...I greased on top and bottom of the piece that the bar slides into. This is the point that swivels and is metal on metal contact. I greased it by pulling bar perpendicular to truck and greased top and bottom and worked the bar parallel to truck and back to perpendicular. I did remove a lot of this grease on the way home however.
You can also tighten the bolt that it causing the tension at this point. I have thought about doing that but I am unsure if that will affect the sway. To me the most sway control should be at the friction point where the bar meets the l bracket and not on the hitch where the bar slides in. Correct?
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
