Ron_Gratz
Jun 24, 2013Explorer
2012Oudoorsman wrote:Not correct.
You can also tighten the bolt that it causing the tension at this point. I have thought about doing that but I am unsure if that will affect the sway. To me the most sway control should be at the friction point where the bar meets the l bracket and not on the hitch where the bar slides in. Correct?
The majority of the sway-control friction is generated between socket and head.
The socket bolts should be kept tightened to 45-65 ft-lbs.
Ron
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Apr 15, 2020
