Old-Biscuit
Nov 16, 2016Explorer III
IF you are just blowing out and not pumping anti-freeze then no NEED to bypass water heater
Bypassing is so you don't have to use GALLONS of anti-freeze (fill water heater) to get anti-freeze into hot water system
Open water heater drain, open rv low point drains and then blow opening closing drains/faucets etc (water heater drain plug will need to be back in place to build pressure/blow hot lines)
