srt20
Nov 16, 2016Explorer
Yeah, drained everything, low points, water heater, fresh tank. Then added air psi with everything closed except WH drain. Then closed WH drain, and blew out everything one at a time. Toilet, shower, sinks, outside shower.
Never touched bypass valve.
So, IMO I see no reason to touch it. WH was pressurized with air, and was drained. In fact, after I had disconnected the air compressor, I still had air psi in the plumbing. I opened the bathroom sink for some reason and had air psi come out.
Im not trying to debate, I obviously don't want to bust any lines, but I just don't see how it needs to be bypassed when using air. If anybody can show me why, then I will gladly do it.
The reason why I don't want to bypass in the first place is because the WH is under the kitchen sink and needs a panel to come out to access it. Not a big deal, but I just don't see a need to do it.
BUT, I will be accessing it anyway now to check for vertical hose with water in it as Bumpy mentioned.
I am taking air compressor with me anyway, because I forgot to blow out the black tank flush.
Thanks guys!
Thanks guys!
