XR4rider's avatar
XR4rider
Ram 3500 4x4 Superglide setup questions
Hi,
I have been reading through various forums and trying to get some advice on the Superglide setup with my 2017 3500 4x4 megacab 6'4" bed (without factory fifth wheel prep and without factory air bags). Because of the standard bed I think I am leaning toward an Autoslide.
The trailer I will be towing is a newer fifth wheel but it has a light hitch weight of about 1,330 lbs. I am concerned with the light hitch weight that the trailer will be nose high.
I will be towing full time so I am not concerned with having a "clean bed" The hitch will stay in the truck bed full time so also OK with standard rails.
Do you think standard rail mounting system with the Pullrite Superglide model number 2700 or 4100 (both 16k hitches) will work? I guess I will need whatever setup that will have the lowest hitch height?
Thank you.
Looking for advice before your next adventure? Look no further.25,103 PostsLatest Activity: Jan 21, 2025
