jcandler
Jan 02, 2015Explorer
The center pin - on the plug at the coach is or should be hot ( sometimes the coach ignition switch needs to be on
Run a wire from this point to the edge battery - then you will be charging your Ford Edge battery as you go down the road towing
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 19, 2025
