Tom_Dee
Jun 16, 2014Explorer
ScottG wrote:dodge guy wrote:Tom&Dee wrote:Trlrboy wrote:
Uhhhhhh... you forgot to mention the idling diesel.
I am one with an idling diesel. You need to keep in mind that when I pull into a campground and back my trailer in the exhaust temperature does increase to about 450*. Without idling to cool the exhaust down (time depends on how warm everything is, how hard the engine is worked prior to arriving, etc) the turbo is spinning about 10,000 rpms and shutting it down hot causes the oil flow to stop while the turbo is still spinning and the heat will cause the oil to burn (coke) around the bearings and cause a premature turbo failure. If you are next to me when I pull in I will shut the engine down soon as I arrive PROVIDED you or anyone else puts $1000 in my hand because it will cost me more than that to replace the turbo. Now, I don't let it sit and idle for hours but I also watch the pyrometer and soon as I can I shut it down.
By the time you check in the truck has idled enough to cool down the oil. and by the time you idle through the campground it is cool enough to shut down! no reason to idle it in the campground for up to 30 minutes.
Tom, Your pyro may be bad if it shows it takes any more than 3~5 minutes to drop below 300 degrees - it just doesn't take any longer than that. There's no way the temps are that high after slowly driving around a CG and just maneuvering into a spot.
Again, I shut it down AS SOON AS I CAN, but when I am driving in a campground then backing in my exhaust gas temperatures do climb to about 400*. I am going to let it idle until it cools to a minimum of 350*. Simple as that. and like I said, soon as I can I do shut it down. I don't let it idle for any more than necessary.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: Oct 17, 2015
