CampCritter
Apr 08, 2020Explorer
Lynnmor wrote:
That is the way the junk wears. You can resurface the magnet to get it flat again, and also resurface the brake drum armature. Few shops are equipped with the equipment to do the drums and few can get the high finish required. Usually the armature has a limit of .030" stock removal. I have the equipment to do my own.
Brake manufactures install linings that work very poorly till they are burnished and they recommend doing a process to work the he!! out of them in their "burnishing" process. Well guess what, the magnets aren't seated yet and they are worked too hard with the hard use and high settings. So you either break in the new brakes with them operating poorly or you start the process you have just seen. Of course the delivery guy already abused the brakes before the trailer was ever sold.
I suspect that what is going on is that brake coil in it's unenergized position has its outer edge hanging off the edge of the armature. If Dexter added an 1/8" or maybe even 3/16" to the outer circumference of the armature, then I wouldn't be having this problem. I've wondered if I have drums that were manufactured wrong or perhaps I've got the wrong hubs. That's why I was curious if other people have seen this problem.
Looking for advice before your next adventure? Look no further.25,178 PostsLatest Activity: May 12, 2025
