Generic
May 30, 2013Explorer
luvlabs wrote:
Don't ignore the hitch rating however, are you sure it is a class II? Most hitches on motorhomes are at least class III.
Would you consider towing flat? The number of cars that weigh less than 3500 lbs is pretty extensive and it is easier than a tow dolly. If you have to use a dolly, almost any small, front wheel drive car will work. You got your pick of virtually any of the subcompact cars built today.
As far as I know a class 2 is rated for 3500 lbs max. If that is correct then I am sure I have a Class 2 hitch. The 3500 max is clearly stamped on the hitch by Winnebago.
I have the P30 Chassis. As far as I know a class 2 is about max for that Chassis.
As for towing Flat....I dont think I can do that with a Front wheel drive.
Are there many on this forum that tow dinghys with a P30?I would be interested to know.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
