rvluversnc93
Jan 11, 2015Explorer
I would get them looked at they all need to be opened and cleaned. As for the one sticking if you lost the magnet clip I think the spring would push the magnet right off of the swing arm. If its stays on the clip is probably there. I would check the pin where the arm pivots on top for crude or rust causing it to freeze up. I had one do that without being mudded up and it would heat the brakes up on that wheel. To answer the question of how far and how fast I would be afraid to answer. With an inundation of water/sand/mud mixture there could be problems with the brakes working improperly or not at all. I know this may not be what you want to hear but I myself would be scared to death to trust them. They may work fine and may break down on the side of the road.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Jan 13, 2026
