lakeboi's avatar
lakeboi
Ready Brute Elite Cable Question
Question on the ready brake cable install. Made maiden 40 mile run and the black cable guide has rubbed all the sheathing off the cable that connects the actuator arm to the vehicle. It appears to be the top of the cable, so I assume it is scraping when the ready brake engages and pulls the cable slightly upward and towards the motorhome. The cable guide is cut razor sharp. Is it supposed to be this sharp or do I have the cable run improperly? When I measured, the tow bar was level (within two inches). I have about 2.5 inches of play adjusted in the cable.
Thoughts???
    Thoughts???
    This, like mine is due to left and right turns and as an afterthought, I would have ground the guide edges to 45%. One can still dismantle the cable and do this grinding, but I doubt if it's a problem anyway, as the vinyl covering is most likely the only thing that will wear away and certainly not the stainless aircraft cable.
  • I also noticed some wear on the cable sheathing on my Ready Brute Elite setup. (Components were all aligned per instructions.) I glued half of a hard rubber grommet in the top of the guide where it contacted the cable on brake application and applied a small amount of grease. No further wear detected thus far.
  • Mine is dead center as well. Either open it up, use a different hole in the actuator. Might call NSA.
  • I wouldn't hesitate to open up the guide a bit and smooth it off. My cable runs dead center in the guide when activated though. The toad end of my cable is centered and in line with the tow bar pivot points, and my tow bar is level within a 1/2 inch on level ground.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
