Highway_4x4
Jul 25, 2016Explorer
On a washboard freeway it feels like my truck is being shook apart by the TT. When not towing the same freeway is not as bad. I would take the tire PSI up to the max cold and see if it makes a difference just to start. Is that 620 tongue weight a measured or on from the factory info. If you really need to add weight you might be able to fill a holding tank in front just to see if that helps. Then if it does add the weight.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
