mkirsch
Jul 25, 2016Nomad II
When you adjusted the bars, did you work your way back down to unloaded ride height in the front, or did you hit it "spot on" on the first try?
If you got it "right" on the first try, I submit to you that you probably have too much tension on the bars. The reason being, there are "jounce bumpers" that the IFS 4x4 Chevys ride on at unloaded ride height. It is impossible to push the front end below unloaded ride height. So you may think you're right on, but you're really way over.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
