Eric91Z
Jul 25, 2016Explorer
Thanks for both of those items.
1. I will try air pressure. That is one thing has is on my too do list for sure next time I take it out.
2. As for front ride height with bars, it was actually set by the dealer we bought from, on the day we got it. And basically took it home, loaded up, stopped and weighed, and headed out. Had the bouncing both unloaded and loaded. So, you are right, it could be too much if that is case with bump stops. Although, it looks like they originally had the L brackets up one set of holes further and raised one for how we left with it. So might need to drop brackets back down and re-measure. As well as getting front height with trailer hooked up, but WD bars not on.
3. Tongue weight is based on loaded truck weight (from scale) minus unloaded truck weight (from scale). So it was difference of the two weighed weights from scale weighing.
4. One other thing we weren't aware of, is that there was a fair amount of water in the fresh water tank. Not sure when that was there. We only were hooked up to City Water connection and shouldn't have been filling the holding tank, but did make sure it was empty before leaving the site and it drained quite a bit out.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
