Eric91Z
Jul 25, 2016Explorer
BarneyS wrote:
According to his numbers, he is not trying to push the front axle below the stock unloaded ride height. He is .25in above the stock height when the WD bars are tensioned.
This is probably just about right but I would try to get the bars parallel with the A frame so that they ride flat on the L brackets. I think I would lower them one hole and tilt the hitch head back by adding at least one more washer. For the standard sized A frame, Equal-i-zer recommends starting out with 5 washers in the hitch head and he only has 4. When he lowers the L brackets to make the bars level then he needs to tilt the head back some more to keep the same tension on the bars.
What he describes sounds like he could use a bit more tension on the WD bars so I would add two washers and try it out. Can always take one out if it puts too much tension on the bars. The porpoising he describes is a typical result of not enough bar tension.
Barney
So I have heard two possible causes: 1. Not enough bar tension and 2. not enough tongue weight...
So first step, drop L Brackets one spot for bars to be parallel with a-frame and one or two washers to head to tilt that a bit and try that?
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jun 29, 2026
