3oaks
Jul 25, 2016Explorer
BarneyS wrote:Having quite a bit of experience with the Equal-I-zer 4 point hitch, I believe Barney has given you some very good advice and logically so.
......................According to his numbers, he is not trying to push the front axle below the stock unloaded ride height. He is .25in above the stock height when the WD bars are tensioned.
This is probably just about right but I would try to get the bars parallel with the A frame so that they ride flat on the L brackets. I think I would lower them one hole and tilt the hitch head back by adding at least one more washer. For the standard sized A frame, Equal-i-zer recommends starting out with 5 washers in the hitch head and he only has 4. When he lowers the L brackets to make the bars level then he needs to tilt the head back some more to keep the same tension on the bars.
What he describes sounds like he could use a bit more tension on the WD bars so I would add two washers and try it out. Can always take one out if it puts too much tension on the bars. The porpoising he describes is a typical result of not enough bar tension.
Barney
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
