Eric91Z
Jul 28, 2016Explorer
Gotcha on the unloaded vs. loaded with WD bars attached front axle weight. That all makes sense.
Trailer tires are at 65 psi cold as checked yesterday. Bumped truck tires to 42 psi front, 46 psi rear (max is 51 psi). Got the hitch ball height measurement today. Will get the tongue height when trailer level today and get the CAT scale weight when hitched up, but WD bars off when I get trailer tonight, too. Also getting front fender height hooked up, bars off, as those should be rest of numbers I need.
The sheet that came with the trailer from the factory says the UVW of trailer is 6076 lbs and hitch weight it 574 lbs. I have not done a formal tongue weight weigh yet.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 17, 2026
