Community Alumni's avatar
Community Alumni
Sep 26, 2023
Reasonably decent towed vehicles for a Class A
What are some reasonably priced vehicles suitable for flat towing behind a Coachmen Mirada 32ss? I know several Jeep products are suitable along with most manual transmission vehicles but it would help me choose a vehicle if I could get recommendations from others with Class A rigs. We just bought a new-to-us Mirada and are looking for a suitable toad.
  • CA Traveler wrote:
    ...CRV up to 2014 can be towed. The 2014 can be towed as well. All CRVs (FWD and AWD) can be towed four down.
    Flat towing also involves a tow bar, base plate, aux brake, lights and possible charging line...
    I'm towing my second CRV, great tow vehicles.
  • I tow a Smart car. I have one set up with the Roadmaster deal so it can be flat towed and one that is not. I thought the Roadmaster deal was the way to go after reading about it forever but have only used it a couple of times as it takes to long to hook up and the first time I used it the "death wobble" got me. So, I use a dolly which allows me to tow any of our cars that are front wheel drive and takes no time to hook up. I also have a Featherlite car trailer if I want to take something else. I am also 82+ years old. Get what suits YOU and get on out here.
  • We have a 13 Explorer that we tow. It’s 4WD but this generation of Explorer can also be towed if it were only FWD. the Ford Edge of similar years can also be towed.
  • Jeep Cherokee Trailhawk. Excellent, light weight and built-in tow option. As mentioned, add a braking system and you are good to go. We use the M&G but there are others.
  • Problems can occur when towing that existed at mfg. An excellecent recent example is death wobble due to EPS which has less damping than hydraulic steering. Do extensive homework on any car because even as a DIY setup is expensive.
    Tom is correct as toads represent a very small market for mfg and that market is quickly ignored when other factors are considered.
  • The number of NEW vehicles that can be flat towed is declining. There are quite a few older cars that can be. I towed Jeep Wranglers, and Chevy Sonic’s. Both easy to tow. Previous post gives info on where to look for more models.
    When decide on a vehicle, check out NSA’s Ready Brute Elite which is a tow bar aux brake combo. Very easy to set up and use.
  • The Dinghy Towing forum is better suited for your question. Perhaps do some searching there. FMCA and Motorhome magazine both publish towing quides. CRV up to 2014 can be towed. My current Jeep might be heavier than you want. Both of these cars have automatic trannys.
