camper_ron's avatar
camper_ron
Receiver Hitch broken
Have a Hidden Hitch Model # 64-6100 that cracked on the weld. I brought it to a seasoned welder and he rewilded it after about 600 miles it broke again. Was wondering why it says on the hitch not to weld? This is on a 2004 motorhome towing a 2004 jeep liberty. I know just replace it but not very easy to find a replacement.
Thanks for any inf .... r0n.....
  • Check to make sure tow bar is nearly level. Make sure it is pivoting side to side. If it is not, turning straight corners could rip the weakest portion to pieces.
  • enblethen wrote:
    Is this the hitch on the MH? What chassis is it on?
    Best guess the tow bar is not turning on corners. What tow bar?
    Draw-Tite 5350 Multi-Fit Motor Home Hitch
  • 2004 motorhome towing a 2004 jeep liberty using a Blue OX tow bar. :(
    Dutch_12078 wrote:
    The Draw-Tite 5350 or Curt 13701 should fit your motorhome. Both are adjustable up to 51" and are rated for 5,000 lbs.
    Draw-Tite 5350
    Curt 13701
    Some thoughts: Mfg welding may be much more controlled, inspected and tested. Maybe even machine controlled welded. Welding also involves a lot of heat which may be part of the mfg consierations perhaps even some level of heat treatement. Or maybe it's a liability statement.
  • Is this the hitch on the MH? What chassis is it on?
  • I have 3 Class IV hitch receivers that were bolted onto my dodge ram trucks years ago by a welding shop and no problems so far towing 4500lb trailer in many states.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
