coolmom42
Jun 16, 2017Explorer II
hotpepperkid wrote:
How often do you have recertify you propane tanks
First of all, you don't have tanks (normally) on a 5th wheel. Tanks are the permanently attached things on motor homes. What you have on 5th wheel or trailer are CYLINDERS.
Why is that important? Because the inspection requirements are different.
For cylinders, the rule effective in 2017, is every 5 years for visual inspections, and every 10 years for a pressure test or a similar test, called "volumetric expansion."
DOT rule
This page explains the differences in tanks and cylinders, except that the inspection period for cylinders has not been updated:
Tanks vs cylinders
Looking for advice before your next adventure? Look no further.25,201 PostsLatest Activity: Jul 05, 2026
