George3037 wrote:
This discussion has been here before but I couldn't find the thread on it.
The OEM hitch on my 2016 2500HD is a V5 2 1/2" Factory rated at 1300 tongue and 13000 max trlr. There were some others that had a higher rated which I believe was either 1700/17000 or 2000/20000. They may have been on a 2WD truck. Mine is 4WD CC short bed. The sticker is on the bottom so you have to lay on your back to see it. If yours isn't there then it fell off.
2015 GMC 2500HD SLE 4WD Double cab with 8' bed
20K lb rated, 2K lb weight carrying.
The GM hitch issues were prior to 2007 and for the most part were 1500's, but some of those hitches made it onto 2007 classic and prior year 2500's depending on configuration. It's easy enough to tell as those hitches had two bolts attaching them to the bottom of the bumper.
