- BobboExplorer III
Aimcat wrote:
2008 Dodge 1500 hemi. Max tow for it is 8200
What is its available payload? That is far more important than what its tow limit is. - LIKE2BUILDExplorer
SoundGuy wrote:
Tekonsha P3 brake controller, Blue Ox Sway Pro weight distribution system.
I used a Tekonsha Prodigy P2 for 10 years with flawless operation.
You definitely want a WD hitch.
My hitch was a Reese Dual Cam system and it worked perfectly as well. The trailer was 34' long and the Dual Cam kept it from any kind of sway in even the worst of cross winds. Of course the #1 sway is to ensure the trailer sets level when the bars are under tension and that proper weight is transferred to the front axle. The sway control should only be needed when external conditions induce it.
KJ - downtheroadExplorer
Excellent recommendation. - AimcatExplorer2008 Dodge 1500 hemi. Max tow for it is 8200
- LwiddisExplorer IIRegarding a weight distribution hitch, more than likely yes. Length is only one part of the equation...your TV is what? Wet hitch weight is? Wet TT total weight is what? What are you carrying in the TV? Sorry but I'm betting you have no idea as to weight.
- SoundGuyExplorerTekonsha P3 brake controller, Blue Ox Sway Pro weight distribution system.
Looking for advice before your next adventure? Look no further.25,179 PostsLatest Activity: Dec 22, 2025
