Baja_Man's avatar
Baja_Man
Recommended WD Hitch for TW between 1300#-1800#?
Looking for recommendations on a WD/Anti-Sway hitch for a 30' toyhauler I will be purchasing.
2009 Tahoe 284SA
I have not weighed tongue yet, but estimated weight is between 1300#-1800#.
I've had Equal-i-zer 4 pint hitches in past and they worked great.
But they max out at 1400#TW. If my TW is below the 1400#, I would chose it gain. But if higher , what are my options. Not considering Pro Pride or Hensley due to cost.
Thoughts/Recs?
Thanks!
  • There is no point in re-hashing information that you have already received in your other thread here. . Just go back to that thread and ask if you have new questions.
    I am closing this one.
    Barney
  • I would suggest you post the make/model of the Toyhauler.
    Since a lot of the weight with them is from the toys in the rear, tongue weight may not be as high as your guessing. Maybe someone on here with one can give some insight if you post the info.
