JBarca
Jan 03, 2014Nomad II
myredracer wrote:
We have a new TT coming shortly and it has an 8" high frame on it. Does this mean it will have a taller A-frame too? We presently have a Reese DC WDH with trunnion bars that I just love. If the A-frame is over 6" in height is the Reese WDH going to work? If the A-frame is 7 or 8" tall, will a round bar type work? I prefer not to use a round bar type. I don't want to use any type of friction-based WDH so would the fancier WDHs work on a taller A-frame?
I know there can be clearance issues with the Reese DC which can be resolved with a taller ball mount. But will this work with a taller A-frame?
This just occurred to me and I want to make sure I have anything I need before the TT arrives.
To the 1st question, just because you have a 8" main frame rails, does not means you have an 8" A frame. They step down the A frame when attaching it. I have 10" main frame rails with a 6" A frame. However there are 8” A frames too, just not as common and are very heavy tongue weights.
If you have the trunnion bar hitch now, keep it and use it. It has more advantages over the round bar. That said, you will need to set the trunnion bar hitch up correctly so it does not bind in turns.
Before we go to much further on what the fix is, we and you really need to know these facts.
1. Is the ball coupler on top, in the middle or the bottom of the A frame?
2. What is the width of the A Frame? 4", 5", 6", or 8" are common size steels. 7" is not. 5" fits channel iron but not rectangular tubing. Not that it is impossible to make a 7", it just is not a common steel size. If you have 8" frame rails this points to a heavier camper, 6” is common on trailers in the 7,500 to 12,000# GVWR range. But again need to know what it is you really have.
3. Is your camper a real low rider? Is there at least 13” from the ground up to the bottom of the A frame?
Tell us this or find it out and we can help better. The trailer manufacture knows the answers to those question. What brand, year and model is it? We can look it up and may be able to help identify it.
Congrats on the new camper. Hope this helps
John
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
