JBarca
Jan 04, 2014Nomad II
myredracer wrote:
Just to clarify, my question is what are we going to get with 8" tall I-beams for height of the A-frames? And if it's over 6", is there going to be issues?
If 6" I-beams have 5" A-frames, would 8" A-frames have 7" tall A-frames or could they be 6"? Or maybe they mount the coupler a bit lower?
myredracer wrote:
You can find lots of tech. info. on axles from Alko and Dexter but with frames, there's nothing.
Hi again RedRacer,
You have 2 areas of question, the A frame and the hitch setup. I will address each separately and start with the A frames.
An 8” tall main frame rail is large for a 7,000# GVWR camper. It is not a bad thing, you said it was special order so good for you. I would rather have HD then light in a frame. Just because you have an 8” main frame rail does not mean you will have an 8” tall A frame. And odds are you will not. As I said in my prior post, I have 10” main frame rails and a 6” tall A frame.
That said, yes I have seen an 8” A frame on a TT, not common however this was a 10,000# GVWR area camper. The loaded TW drives it to 8" most of the time. And we had a cargo trailer here on RV.net a number of years ago a member wanted to get a DC to work on an 8” A frame. The cargo trailer being a low rider trailer was an issue to get the DC to work however it was overcome with proper setup of the hitch.
You mentioned if 6” I beams have 5” A frames then does 8” main frame rails have 7”? Well it does not work that way in practice. I have seen 5” main frame rails with a 5” A frame, 5” main frame rails with a 4” A frame, 6” main frame rails with 4” A frame etc. And as I said I have a 10” main frame rail with a 6” A frame. There is no exact industry standard.
About the only thing close to somewhat standard in the RV industry on TT A frames is, most are setup on a 50 degree inclusive angle of the A frame. And that is about it other than using many use a 2 5/16” tow ball. Some small TT's use a 2" ball. Everything else is whatever the frame designer wants to use.
The main frame rails may be made from the RV industry I shape, (notice I did not say I beam) or 2 stacked rectangular tubes making 10 to 12” tall main frame, or channel iron etc. Then there is the hangers if you are on leaf springs which have many different lengths and mounting methods. Add to that the axle on top or bottom of the spring, low slung axles and then different length springs with a different arch height. Then there are tire diameters and does the camper have a slide or not to name a few of the combinations to work through.
All those combinations create the right tire bump clearance above the tire to the bottom inside of the fender and the top of the axle tube to the bottom of the main frame rail. Now the main frame rail heads all the way to the front of the camper with many being a simple straight shape. Some of the ultra-lights even taper the main frame rails to save weight.
Once you get to the front of the camper there is a header that ties the left and right main frame rail together and to help hold up the front of the camper. Now you need to attach the A frame to the main frame. Here again we have several different methods on how to attach the A frame and then the ball coupler to the A frame. Again I have not been able to find a published standard on how to build a TT frame. That said, there are a few common methods in the more traditional approach. Some A frames attach under the frame rails, some A frames go through the header and there are multiple ways to go through the header.
See this link to a post I did a few years ago asking if anyone knew what the rating of their A frame was. How big a WD bar can you use and what is the max tongue weight it can hold before failure. Well no one that I have found yet has posted about that as it is not a commonly know rating. I do know Jayco on some of their light weight TT frames puts a sticker of max 1,000#WD bars right on the A frame. And I semi recall a Forest River new Back Packer series TT with a sticker too. Those stickers came from prior experience of bent ultra-light A frames from too heavy a WD bar. This link will show you several campers in the 7,000# GVWR range and how the A frame attaches to the camper.
TT A Frame Ratings
You stated you have 5” tall A frame now on your existing camper. If I understood that right. Since your new one will have a HD frame, they may up size the A frame to 6” however I doubt it will be more than this. And if it is 8”, OK you can still make it work but I really do not expect a 7,000# GVWR camper to have an 8” tall A frame.
The ball coupler, there are more 2 common mounting methods of the ball coupler on a TT that I have seen. I admit, I have not seen all of them... and do not declare I have. What I am going to say is not the absolute, so let’s call it "common".
Ball couplers on a TT for the most part are on the top or the bottom of the frame. There are others, some in the middle, however they are not as common. The different methods are used to somewhat establish a workable ball height to mate up with the truck and how the camper frame was made. Again back to the combinations of tire size, frame size, axle on top or bottom of springs, slides/no slide, to name a few and then how the A frame was attached to the main frame rails. The designer can pick a ball coupler to help hit the target of the ball on the back of the truck.
For the sake of this reply, we are only talking about TT's and TT's that use a WD hitch. There are a number of other style ball couplers and some used on a TT, but not as common as the 2 I'm going to show. Each of these create a slightly different setup of the DC and Reese WD hitch.
Here is the top mount, a common method used as many brand campers. It welds on the top of the A frame. There are several manufactures of these, Fulton is one of them. I think your existing coupler is on top.
Fulton ball coupler
Another is Shelby ball coupler
And Atwood Mobile ball couplers See page 24 of the PDF.
Here is one of mine with the ball coupler on top
The other somewhat common us a bottom mount coupler. Jayco uses this a lot with their larger slide camper setups. This is one of my camper buds, Turk2500’s setup
Both have different needs for the DC setup. However both can be made to work including an 8” tall A frame. That one is a little tougher, but doable.
Once you find out how tall your new A frame will be, is it C channel or rectangular tubing and is the ball coupler on top or the bottom we can hone if you need to buy any special hitch parts to make your existing Reese WD hitch and DC work with it.
I’ll address the WD hitch in the next reply.
Hope this helps
John
PS. You mentioned something on TT frames not being much posted, there are some posts, mainly stemming from a frame failure, A frame failures or twisted spring hanger brackets. I see FisherGuy joined in, he had the web crack issue. I beefed up my frame so that I shape lower flange problem would not occur and how to deal with long hangers. See here. TT Spring Hanger Stiffening (Long, lots of pics)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
