mrekim
Jan 11, 2014Explorer
myredracer wrote:
I guess you just cut the end covers off and weld new ones on?
yes
myredracer wrote:
You mentioned that you shouldn't do vertical welds on a frame. I haven't heard that before. What is the reason behind that?
Distortion? Is it everywhere or just in higher stress areas? Does it matter if it's gas or MIG welding? Can you do a stitch weld pattern vertically?
I'm not sure of the reason, I think it has something to do with the heat (haze area?) from the weld making the steel somewhat weaker or more brittle. You can search for fishplate and frame to find some discussions. Some also do an internal circle or diamond on a plate.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 07, 2026
