HouseApe
Oct 19, 2018Explorer
The cam brackets. I do have the one with the welded inside 90 like the right hand one in your photo.
My consern is with the bent 90. It’s not at 90 it’s about 88. So with the cam brackets flat on the bottom of the frame and the welded 90 flat to the inside of the frame the bent 90 on the outside is about an 1/8” out at the top compared to the bottom.
The rivenuts would be proud of the hole and would require the bracket to match in my mind.
If I bolt it up it will pull the bottom of the brackets off the bottom of the frame by about 1/8” on the inside of the frame.
I’m going to call Reese and see what they say before I drill anything.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
