HouseApe
Aug 22, 2019Explorer
TUCQUALA wrote:
Get some sheet metal approx the thickness of the rivet heads, make a couple of shims that fit around rivets, and bolt up!! Been using method on 2 different trailers for the past 9 yrs. No problems, PERIOD!!!!!
That’s not the issue. The issue is the cam frame bracket is not at 90 and is not sitting flat on the bottom of the frame causing the cam arm to be at an upward angle. I would have to make a tapered shim to correct this.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
