lamopar's avatar
lamopar
Reese head loose on shank
I have a Reese Titan shank and the trunion style head. When the bolts are as tight as I can possible get them the head is still loose on the shank. I see it calls for 300 lbs torque. Can the cast head actually squeeze onto the shank to keep it from moving up and down?
Looking for some guidance here. I am going to purchase new nuts and bolts and try again as these seem to have the threads rolled and one bolt is bent. It took a 1" drive rattle gun to get the nuts loosened back up and it took a lot of time. Still the shank and head were not tight.
  • There should be 2 steel shims that fit inside the head with matching holes for the bolts to the shank. They are for such a problem. From installation guide:
    "OPTIONAL SHIM KIT
    Use the shim provided when needed to fill any gap between the Weight Distributing Head shown below and the hitch bar
    used in the particular application.
    It is easier to install the shim from the top down as shown on the following page. In doing so, you will encounter one of
    three scenarios:
    1. Shim will go all the way down to line up with the bottom hole. If this is the case, use the entire shim in
    the gap.
    Note: It is conceivable that in some rare combinations, two shims could be used. In these cases,
    contact Customer Service at 800-632-3290 or 800-428-7303 for a free additional shim service
    kit #58207.
    2. Shim will not begin to fit between the head and hitch bar. If this is the case, discard shim and continue
    installation. The existing gap is acceptable
    3. Shim will not go in far enough to reach bottom hole.
    If this is the case, cut shim in half and use only the
    top half for the top bolt. Discard bottom half of shim"
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 18, 2025
