Lost_Traveller's avatar
Jan 11, 2018
Reese sidewinder wear plate
We installed a reese sidewinder on our fifth wheel. When we attached to the mounting brackets on the fifth wheel we didn't check for clearance between the turret and the mounting bracket wings. We had a steep grade to back into our camping site. We ended up bending one of the brackets and tore some of the wear plate. You can't just order a new wear plate. You have to order a whole repair kit at a price of $222!
My first question is, did we hurt the integrity of the bracket bending it? My second question is, does anybody have any idea of a comparable material that maybe I can make my own wear plate or any other alternative.
I'm almost thinking of bending the other bracket on the RV if I didn't think it would hurt the integrity of it all.
Thanks in advance if any of you have any ideas.
Bruce and Connie
  • Thanks for the info Old-Biscuit. When we were searching for the part, we only came across the total replacement kit. I noticed they only had one in stock, so I went ahead and ordered it.
    I'll also "modify" the mounting bracket so I won't have this issue again. I didn't want to have to raise the RV any because it sits good and level right where it is.
    Again thanks.
    Bruce and Connie
  • Sidewinder Lower Wear Plate...$57
    IF the 'bracket' you bent is the mounting bracket that pin box bolts onto you can 'modify' that w/o causing any issues
    Any portion of the mounting bracket that hangs below pin box can be 'trimmed'----just cut it off
    Before modifying (hitting truck bedrail)
    After cutting off lower portions
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
