myredracer
Sep 10, 2015Explorer II
ChooChooMan74 wrote:
If the next hole down is too far, you can always get a 1" riser ball.
That's the solution that I'm looking for - least cost and easy to find part. Thanks! I forgot all about those.
I want to drop the nose of the trailer a little to see if it helps handling or maybe braking. It's at or slightly above level at the front depending on how the truck and trailer are loaded up. I haven't got quite enough weight transferred back onto the steer axle and when I do the adjustment, I expect the ball will go up a little too.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Aug 31, 2026
