pianotuna
Feb 09, 2014Nomad III
Hi DiskDoctr,
The Y connector on the fresh water filler is something I had not thought of.
I do have a garden hose male connector on the faucet of the sink in the commode, which I use for flushing out the black tank when there is no water supply at dump stations. I have thought of using it in a pinch to fill the fresh water tank in much the way you suggest as I do a lot of urbandocking (boondocking in the city).
DiskDoctr wrote:
You know...if you are going to keep up this rather...ahem...*wild* and cold lifestyle, it may be helpful to put a Y connector on your fill pipe, leading INSIDE the TT (if you can access it from inside?) or even add a fill tank to your FW tank.
You could then use that winterization tube as mentioned and connect a hose from a faucet or wherever to fill your FW tank from the INSIDE.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 26, 2026
