svjim's avatar
svjim
Refrigerator and fueling?
OK, to begin with I never pull into a fueling station without first turning my propane refrigerator OFF. The safety of doing this has been discussed elsewhere and not the subject that I am inquiring on.
I have a domestic dmr702 and the question I have is "If while the refrigerator is running if the battery is disconnected, is the propane then shut down to the refrigerator immediately?"
The reason for this question is that I have a TC and the refrigerator is in a push out which means before fueling, we stop, lower the the steps and push the slide out far enough to allow us to gain access to the refrigerator and turn it off. Then the slide has to be pushed back in before entering into the pumping station. After fueling we exit the pumping station and repeat the process to light the refrigerator.
I had been thinking that having an on off switch for the refrigerator that was accessible from the exterior of the camper would alleviate the need to push the slide in and out for turning the refrigerator on and off. However it has occurred to me that I have a battery disconnect already which is easily accessible from the exterior of the camper. If disconnecting the 12 volt source shuts the propane off also, then doing so is for me as good and probably better then modifying the electrical connections to install a switch.
So can anyone say with certainty that disconnecting the battery will immediately switch the propane off also?
Thanks Jim
Looking for advice before your next adventure? Look no further.25,176 PostsLatest Activity: Nov 14, 2025
