Sam Spade wrote:
retiredtraveler wrote:
Soak the heck out of it in vinegar first.
Actually I would try chlorine bleach full strength first.....with rubber gloves, old clothes and glasses.
Wash it out good, leave it a little damp and then close it for 24 hours and then rinse good.
That should replace your moldy food smell with a chlorine smell.....which should dissipate over time.
For less drastic things I have been using a cleaner with bleach in it. It works good for lots of stuff.....including dumping a bit into the tanks for cleaning.
DO NOT MIX CHLORINE BLEACH WITH VINEGAR OR ANYTHING ELSE. That can result in releasing deadly chlorine gas.
It's chlorine + ammonia that is dangerous. The gas released is not chlorine, but a category of compounds called chloramines, which are almost as dangerous as chlorine.
Bleach + acid (as in vinegar) produces water and salt. Harmless, but with no cleaning power.
But I would not advise anyone to randomly mix cleaning products.
Take out everything removable and wash it by hand in hot water, dish soap, and a dash of bleach. The dishwasher heat will likely warp it. Air dry.
For the refrigerator, I would use vinegar, thoroughly rinse it out, then the charcoal trick. Break up the briquettes and spread them out in some flat pans, for maximum surface area. Leave the door propped open slightly so it can dry out thoroughly.
