GordonThree wrote:
So the surface area and number of tires, brake pads, rotors, drums, etc play no part in your stopping distance?
That is correct.. I will explain why
The force of stopping is the weight of the vehicle (mass times gravity)
(Gravity is a constant for all vehicles) Times the coefficient of friction Thus the heavier the ride the more force stopping.
Braking power if you want to factor in area of tires in contact with road then the amount of force on each square inch of tire is
Weight/Number of square inches
And the stopping power is Friction (Pressure times coefficient) times square inches
So to completly make up a non-existent vehicle let's say we have a 10,000 pound ride with 100 square inches on the road
That's 100 pounds per square inch... Stopping power is 10,000C
now let's increase the number of tires so we have 200 square inches
We are now running 50 psi.. And the stopping power is 200$c or 10,000C (Where C is that coefficient I spoke of)
What happens if we cut the weight in half?
100 Square inches we now have 50 PSI and 5,000 C
200 Square inches it is 24 PSI and again 5,000 C
This is why vehicle size, number of tires and such do not matter.
