vettman1's avatar
vettman1
Remote works, but switches don't on stabilizer jacks/slides
So I'm a new RV owner and I have a Salem Hemisphere 312QBUD that I love, but I'm having an issue with the switches on the unit. The remote will operate the slides, the stabilizing jacks, the awning and light, but the manual switches don't work. It seems to have gone out in stages. First the stabilizing jacks, then the slides, then the others, all on different outings. I've read that there is a reset switch or fuse/breaker for these, but they're not in the regular fuse panel. Anyone had any experience with this or know where these are on this unit? Pictures are GREATLY appreciated!
1 Reply
  • Had a similar situation but it was only the landing gear jacks. Talked to a good tech and he said it would be a ground issue. I traced the ground back from the jacks until I found a wire nut that was loose. Cleaned and tightened and all has been fine since.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 12, 2026
