j-d
Jan 12, 2018Explorer II
Your project has a number of safety concerns. Towed outweighing towing is one of the big ones. There's a lot of debate about towed vehicle braking, but your case looks like one where you'd better do something. Easiest thing would be to find somebody willing to loan/rent you a brake-in-a-box like Brake Buddy.
Rental towbars were used in the days that vehicles had bumpers, not mere plastic trim over foam and sheet metal.
Blue Ox towbars, at least most of them, are meant to connect to a permanently attached Base Plate. They may offer a simple A-Frame to bolt to vehicles like Jeeps and others that have real bumpers or aftermarket bumpers that tie back into the FRAME of the vehicle.
I haven't found a simple bolt-on A-frame towbar with a rating of more than 5000
The Base Plate I mentioned above, secures to the towed's chassis in several places, not just a couple bolt holes, and usually includes backup hardware for inside the chassis. I mention that because a chassis isn't that massive anymore. By that I mean in the last several decades. It's a weldment of relatively thin steel so the towing, turning, and stopping forces need to be distributed.
If the towed is a 2wd with automatic transmission, I'm all but certain the driveshaft has to come out. Pretty much none of those are towable four-down.
I'm sure "People do it all the time" and mostly get away with it. But it scares me.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
