Replies have been turned off for this discussion
- ppineExplorer IIIAcetone is the standard for working around fiberglass. I used to build fiberglass sail boats.
- Grit_dogTrailblazer
wilber1 wrote:
If you have some kicking around, try some Lysol toilet cleaner. You can mix it with hydrogen peroxide if you want to thin it. Don't know if it will work on decal marks but it works great for getting stains of my boat's gelcoat.
Uhhh no. Muratic acid (HCl) is good at dissolving mineral deposits and and organics. It's not a solvent for rubber/glue products. However it will do a great job at rusting any bare steel it touches or oxidizing aluminum severely and as a bonus it will etch your concrete driveway. - Adam_HExplorerLOL, I use camp fuel or Kerosene. Won't hurt paint and we all probably have some. Use it for bug and tar removal on paint too.
Adam - wilber1ExplorerIf you have some kicking around, try some Lysol toilet cleaner. You can mix it with hydrogen peroxide if you want to thin it. Don't know if it will work on decal marks but it works great for getting stains of my boat's gelcoat.
- minnowExplorer
- LwiddisNavigatorSince I have had WD40 on hand at all times since age 17, that’s my choice...but not for bicycle lubrication. .
- mike-sExplorer IIThe first two mentioned (Goo-Gone and WD40 {basically Stoddard solvent and mineral oil})are good choices. I'll add any of the citrus oil ones, like PB Blaster.
- IvylogExplorer IIICitrus air freshener...works the best of anything I’ve tried.
- phemensExplorerJust did mine a few weeks ago with Goo Gone, worked fine, no issues. All the dealer decals gone, looks much cleaner!
- jfkmkExplorer IIIves used Turtle Wax bumper sticker remover, but truthfully I’m with Dutchmen....WD40 works great!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 17, 2026
