Artum_Snowbird
Jun 01, 2014Explorer
Definitely try the lube first. Likely they say drain the tank well and rinse, then add the lube to a small amount of fresh water and work the cables.
Run the cables as much as you can, and collect in a bucket, then put it down the drains and run it a few more times. A few times through will likely fix your problems right up.
There was a thing on here a few days ago.. I think someone tried olive oil or something like that and reported remarkable success.
here you go
here you go
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: May 12, 2019
