oh_boy
Jun 02, 2014Explorer
All depends...I'm going thru this right now. I've had 3 trailers, all with coroplast bottoms. Two were newer and the self tapping screws weren't rusted solid. This last one was hell on earth but I have no choice.
We drove thru a very heavy deluge in late March on I10. The coroplast was screwed every 6-8 inches. We find out water had gotten in under the frame and coroplast soaking the insulation. I usually loosed the screw with a hand socket then use a drill to back them out. Not this time they were frozen in solid.
I eventually cut around the screw heads and popped the coroplast down.
Due to road salt rust I ground the whole frame bed and ground off the frozen heads. Primered and repainted the frame. Changed out the insulation and when it stops raining I will redrill new holes and use a sealant and aluminum flat bar and 3/4 self tapping screws.
This trailer (bought used) must have been driven a lot in road salt conditions. At least I know now whats under the coroplast. Not a fun job...
Try one or two screws if the come off easy enough you're home free if not it's your call which method you use.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
