Campfire_Time
Sep 29, 2014Explorer
PeteK-Hou wrote:TurnStyle wrote:
If you can get under an edge you might try using a piece of dental floss to separate the Velcro from the surface then use goof off to remove the adhesive.
Monofiliment fishing line works a bit better and won't break as easy.
X2. Then work off the glue residue with a little bit of mineral spirits on a soft cotton rag.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 26, 2026
